NI TestStand
Error -18002 with LV runtime
Hi all-knowing forum
In the attached file, I have a VI called CheckFileSrvForGODialog.vi in the ModelSupport folder. When I try to add this file as an "Action" step in TestStand 4.1 I get an error -180002 "The VI is not executable. Most likely the VI is broken...".
I see this error only when I use  LabVIEW run-time engine as my LabVIEW adapter. If I use LabVIEW development as my adapter it runs without errors. (with LabVIEW 8.6).
I have made sure that the correct folders are in the TestStand searchDirectories and I have searched this forum and tried various solutions that I found from others. Bu, alas, none of it seems to help.
Any good suggestions?
B.R.
Martin
(3,866 Views)
Accepted by topic author Lentz
Hello Martin,
Are you running your sequence on your development machine or a target machine that you deployed to? What version of the LabVIEW Run-Time Engine have you configured the LabVIEW Adapter to use? If the CheckFileSrvForGoDialog.vi or any of its subVIs are not saved in the same version of LabVIEW as the Run-Time Engine that you are attempting to execute them with, you will receive Error -18002. Have you tried mass-compiling your CheckFileSrvForGoDialog.vi? Please see the following KnowledgeBase Article for reasons why you might be receiving this error:
-18002 Errors in TestStand
Manooch H.
(3,851 Views)
Hi Manooch_H
I am, currently, running it on my development PC - Later it is supposed to be distributed to our test PC's.
Everything should be mass-compiled, at least as far as I know (unless some subVIs were hiding when I did the mass-compile). I have set the run-time adapter up to use LV 8.6, which is the same LV version that I have used for developing the code.
I will check the knowledge base article for hints, thanks.
/Martin
(3,843 Views)
