NI TestStand
Enable RecordResults for all Steps in testsequence
i have a testplan with ~30 subsequences and each ~100 teststeps.
Some of the steps are manually set in step-property to "Record Results = disabled".
Question: Is there a way to (temporary) enable all results again with one click?
Or is the only way to do it to do it again manually?
(Reason: Currently the testplan fails and i dont know the failing steps as it is one of the dispabled steps.)
(569 Views)
You can build your own One (maybe Two ) click solution: use the API to go through all Steps of your sequence(s) and modify the property accordingly.
Just make sure you also have a way to reverse this after having finished
(559 Views)
Accepted by topic author OnlyOne
If you have access to the Architecting Tst Systems using TestStand  course material, you can use exercise
Exercise 5-2: Create a Tool to Quickly Disable Message Popup Steps
as a starting point
(549 Views)
Use Find/Replace in Files:
1. <Ctrl-Shift-F> to open Find/Replace in Files and fill out as shown:
2. Fill out Filter tab as shown to just find steps:
3. Click Find/Replace:
4. In Find Results, select all steps, change Replace With value to 1, then click Replace Value.
Scott Richardson
https://testeract.com
(538 Views)
