NI TestStand
Edit Close Database Dialog Box
Where do you find the variable that holds the database handle?
(2,152 Views)
You can find all the configuration for a database connection in the "Database Options" callback of whatever process model you're using. You can set the parameters of this callback to configure database options at run time. This article goes through using this to disable or enable Database logging programmatically for example.
Hope this helps,
Jonah
Technical Support Engineer
(2,021 Views)
