NI TestStand
Easy way to extract row from two dimensional array?
Is there an easy way to extract a row from a two dimensional array? I have a two dimensional array that I'm considering as an array of pin lists, where each pin list is an array of numbers. I'd like to iterate and extract one row at a time to send it into a vi. Currently I'm looking at doing it a bit of a long way, and was wondering if there was an easier way. The long way:
GetArrayBounds( Locals.ArrayOfPinsToTestAtOnce, Locals.BogusString , Locals.ArrayBounds ), // Get the amount of rows and columns into Locals.ArrayBounds
Locals.ElementsPerList = Val( Mid( Locals.ArrayBounds, 1, 1 ) ), //Get number of pins per list
Locals.NumberOfLists = Val( Mid( Locals.ArrayBounds, 4, 1 ) ), //Extract number of lists
SetArrayBounds( Locals.OneRow, "[0]","[" + Str( Locals.ElementsPerList ) + "]" ) //Set Array bounds for array of one row
for( int i = 0; i < Locals.NumberOfGroups; i++ ) //Would be done in TestStand step, just for easy reading
    for( int j = 0; j < Locals.ElementsPerList; j++) //Also would be done in TestStand step
        Locals.OneRow[j] = ArrayOfPinsToTestAtOnce[j][i]
    //EXECUTE STEP HERE(Locals.OneRow)
 Thanks for any advice!
(3,783 Views)
Accepted by topic author BClarke
In all honesty, I'd just do it in LabVIEW.  You might want to try to add this to the list in this idea.
(3,772 Views)
I think that'll be the road I take until something is implemented. Thanks!
(3,763 Views)
