NI TestStand
Dynamically set Client file do not stop at pre-defined breakpoints
Hello everyone,
I modified our process model (batchmodel) in order to dynamically set the client test file.
At the ProcessSetup sequence I am using "Runstate.Execution.ClientFile=Runstate.Engine.GetSequenceFileEx(ClientFilePATH)" expresion to set the cilent file dynamically.
But when I set client file by this method, sequence editor do not breaks at pre-set breakpoints. If I press  "Debug>>Break" button it sucessfully breaks the code and then if I insert new breakpoints to the run time copy of code , it starts to break the code at that points.
I could not find a way to read pre-set breakpoints from squence editor and load it to the dynamically chosen client file.
Any idea how can I solve this problem?
(2,018 Views)
Any idea?
(1,888 Views)
