11-29-2016 02:22 PM
I have been trying but out of the box sql buildier is not working with the query to create the schema.
i am no expert on databases or sql queries, if anyone made it to work. could you share your schema?
12-06-2016 04:20 PM
There are known issues with the generation of SQL scripts from the Database Options dialog box.
My recommendation is to start with the default My SQL Insert schema in the dialog and the corresponding script file <TestStand>\Components\Models\TestStandModels\Database\MySQL Create Insert Result Tables.sql, and adjust them both in parallel to obtain the database schema of interest.
12-06-2016 06:28 PM
Today I just managed to make testand log into a local mysql database. I am gonna try to create the schema with the same query I used for the local database
