NI TestStand
Disabling logging into the TestStand.
Is there any chance to get rid of the loging-in window in the TS?
Or can I pass current user credentials to be automatically accepted by the TS?
(4,252 Views)
Accepted by topic author MimiKLM
If you configure a user, whose name equals your windows login name, you can select "Automatically Login Windows System User" in the User Management section of the TS options.
This will suppress the dialog if the user is known in TestStand; if not, the dialog will still appear.
Norbert
Norbert
Expert: Geometry
(4,250 Views)
