NI TestStand
Disable break points column
Hi Ppl,
I'm using the LabVIEW code of the full featured user interface. I want to disable the break points column from the sequence file steps view. I tried setting the station option enable break points to false. This disabled the break points but still the break point column was still there and I was able to set disabled breakpoints(white colored one) in the sequence file steps view. In the sequence file step view control properties also I couldn't find any column for the break points. How do I disable the break points column.
Message 1 of 1
(4,057 Views)
