NI TestStand
Design Document
Do you have any template for design document for test stand?
(3,846 Views)
Are you talking about a document to design your automated test?  Or do you mean a template sequence file?
"Design Document" can mean quite a lot of things to different people.  Can you be more specific?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,841 Views)
Hi Jigg,
Design Document means Design specification document or software design specification document
for more information please visit this link http://en.wikipedia.org/wiki/Software_design_document
(3,823 Views)
You do not need any special template. As part of the process you would assess the requirements and choose the Software Language and Software Tools that you would used in the project. These you would detail in your overall SDD.
Regards
Ray Farmer
(3,817 Views)
Hi Ray Farmer,
i agree that SDD contains all information about Software Language and Software Tools  but in that document we need to specify inter dependancy of modules and objects(in teststand interdependency of sequences and work flow of sequences)
how to create diagram in TestStand sense(for eg, UML diagram)?
 for the above requirement do we have any template or example document?
please share if you have any such document, it`ll be helpful for me,
Thanks in advance
Kind Regards,
Prashanth
(3,815 Views)
Normally customers come up with test requirement specifications and then proceed to develop the sequence.
In the sequence they ensure good documentation by giving appropriate comments/labels.
Teststand can generate a document from your test sequence  which serves the purpose of design document.
Teststand is not really much different from C when it comes to software design.
TS <---> C
Main sequence --- main()
Sub sequence --- function()
Modules ----- library function
As in C you can call functions directly or in a seperate thread.
Whenever a module is developed ( in any language) then it will have its own SDD and that detail need not be covered at tesstand level SDD.
I would suggest :
Use any standard SDD template ( you will find plenty if you google it)
A flow chart to depict the flow of sequence.
Embed the documentation created from sequence ( after sequence is fully developed)
This should make a good SDD.
Hope this helps.
(3,811 Views)
