NI TestStand
Deplyoment Utility Error: Incorrectly Specified Code Module with Property Loader from Database
I have a testsequence with a Property Loader step with the fallowing configuration:
In TestStand Development the sequence runs fine.
If I wan't to Deploy the Testsequence with the Deplyoment Utility the analyzer gives the fallowing Error:
"The code module paths specified in the following steps are empty, invalid, or could not be found on disk. (Message Code: -19056)
Property Loader (ID#:YkbDd+0x7hGA52TWmpsKwC) [Property Loader step type]"
Is there a mistake in my Property Loader configuration?
Best regards
(1,832 Views)
If you have given absolute path try giving relative path as the error is pointing out to the file missing.
(1,799 Views)
Hi RaviShrigiri
Thanks for your reply!
Do you mean in the "SOURCE LOCATION"?
I don't have a file Path in the "SOURCE LOCATION" i use a Connection String see below:
(1,779 Views)
