NI TestStand
Deployment errors
Tried a full build, with installer and ts engine. Builder complained about unsaved files. I told it to it was OK to save them since I handn't modified any. Then it gave me this list of errors. Why would it be looking in a Documents directory? Actually there is not Documents directory under All Users.
thanks,
jvh
Error: Unable to find all subVIs from saved VIs, either a subVI is missing or the VI is not saved under the current LabVIEW version.
The missing file path is:C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\UTILITY\config.llb\Open Config Data.vi
Try loading the following top level VIs and using File->Save All:
C:\Documents and Settings\All Users\Documents\National Instruments\TestStand 4.2\Components\RuntimeServers\LabVIEW\Server.llb\TestStand - LabVIEW Runtime Server.vi
C:\Documents and Settings\All Users\Documents\National Instruments\TestStand 4.2\Components\RuntimeServers\LabVIEW\Server.llb\TestStand Server - Get Window RefNum.vi
C:\Documents and Settings\All Users\Documents\National Instruments\TestStand 4.2\Components\RuntimeServers\LabVIEW\Server.llb\TestStand Server - Hide Window.vi
C:\Documents and Settings\All Users\Documents\National Instruments\TestStand 4.2\Components\RuntimeServers\LabVIEW\Server.llb\TestStand Server - Minimize Window.vi
C:\Documents and Settings\All Users\Documents\National Instruments\TestStand 4.2\Components\RuntimeServers\LabVIEW\Server.llb\TestStand Server - Window Refnum
C:\Documents and Settings\All Users\Documents\National Instruments\TestStand 4.2\Components\RuntimeServers\LabVIEW\Server.llb\TestStand Server - PostMessage Master.vi
C:\Documents and Settings\All Users\Documents\National Instruments\TestStand 4.2\Components\RuntimeServers\LabVIEW\Server.llb\TestStand Server - Not a Window Refnum while Processing VIs...
Message Edited by jvh75021 on 02-24-2010 04:02 PM
(3,945 Views)
Accepted by topic author jvh75021
Hi jvh,
What version of TestStand are you using?  Also, when you navigate to the Open Config Data VI in Windows Explorer, do you find it?  The Documents directory is actually called Shared Documents.  This exists on all Windows XP machines.  Try following the steps suggested.  That is, opening all of these VIs and choosing Save All.
Todd V
NI Prototyping Community
(3,928 Views)
Using 4.2.
Finally got a build after several iterations of opening the files it brought up.
The root problem that the check box for look for broken vis after build was checked.
Thanks for the post, TV.
(3,922 Views)
