NI TestStand
Database Logging
I am trying to use the logging to database feature. I have created a database on a remote machine following this guide: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kKLzSAM&l=it-IT. I have checked the connection and it works. I have built the schema and imported in the database (First Problem: in the Generic Recordset (NI) schema the table PROP_ANALOGWAVEFORM is present two times, and that gives exception in running the Sql script).
After this I have tried to log the data of a simple sequence whit a pop-up and a pass/fail steps. The issue is that sometimes the following exception comes out and I cannot understand why if there is an error in the database creation or if it is a problem of TS.
I am using TS 2021 and ODBC version 8.0.32.
Thank you for the help!
Best Regards,
Zuc
Message 1 of 1
(1,534 Views)
