NI TestStand
Customizing the style sheets
Hi all...
I need to customize the style sheets that come with Test stand.?
How can i go about...?
If i'm correct these style sheets use javascripts...
I only need to change the template... i.e the tables,the headings...
Is it possible to populate the reults directly in to Excel sheets without generating the
xml files. Which call back should i override to do this...?
(3,854 Views)
You can change the stylesheets but NI does not support this.  So you have to know how to do it on your own.
They are stored in: C:\Program Files\National Instruments\TestStand 4.0\Components\NI\Models\TestStandModels\StyleSheets.  I highly recommend you copy them to: C:\Program Files\National Instruments\TestStand 4.0\Components\User\Models\TestStandModels\StyleSheets.  Notice the difference is NI vs User.  That way you still have the original stylesheets.  There's a wonderful xml tutorial here: http://www.w3schools.com/xml/default.asp  They do have Javascripts in them so you will have to figure that out as well.  If I were you I would copy an existing stylesheet (out of the 3 provided) and then add to it and change the name.  That way you can easily revert back to the old ones.  You can choose your stylesheet when you change the report options.
I don't understand how you can open a file in Excel without first generating it.  If you just generate a temp file you still have to generate something.  If you want the report to open up directly in Excel you first must make sure that excel supports your stylesheet and scripts.  Then you can change your External Viewer to be Excel.
Configure>> External Viewers...
Add and browse to excel.exe (C:\Program Files\Microsoft Office\Office12\EXCEL.EXE) or something like that depending on your version of Excel.
Change the format box to xml
check the Automatically Launch Viewer box.
If you are sick of the xml files being populated on your machine you can check the User Temporary File box in the Report Options.
Hope this helps some.  Let me know if you have any quesitons,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,842 Views)
Thank you ~jiggawax~  ,
Your reply was very useful...
(3,829 Views)
Just an FYI for completeness, TestStand 4.2 features improved XML Style Sheets that are restructured to reduce the time required to generate HTML output from XML report files and to simplify the task of modifying style sheets so that you can change the appearance and content of XML reports.
For more information about customizing TestStand XML report style sheets and using the included XML schemas, refer to:
NI TestStand Help: XML Report Style Sheets
Jervin Justin
NI TestStand Product Manager
(3,561 Views)
