NI TestStand
Customize xml report
Hello everyone,
I am working on customizing report. I use horizontal.xls. I want to merge all table. I want to see only one table.  How can ı fix it? I need only one title also.
(3,478 Views)
It looks like one of the better ways for you to do this would be to edit the XML report. Here are some documents that you might find useful:
How to Modify a TestStand XML Report
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAIBSA4&l=en-US
Sections in XML Report Style Sheets
https://www.ni.com/docs/en-US/bundle/teststand/page/sections-in-xml-report-style-sheets.html
(3,439 Views)
I have been unable to solve this problem. Is there any people who solved this?
(3,294 Views)
Hi standalone,
The resources linked in the original response are likely the best route. I don't believe there's going to be a way to get what you want without editing the style sheet. Unfortunately, I can offer no more guidance on how to edit the style sheet, as it requires familiarity and aptitude with XML.
I'd recommend diving into XML tutorials/lessons to learn how it works, then approaching the style sheet.
Kevin S.
Technical Support Engineering
(3,279 Views)
