NI TestStand
Customize teststand tool menu
I need to show only the customized tools menu (not default tools menu) in teststand user interface. How to do it.
i am using teststand 2016. For operator interface i am using shipped full feature OI.
Anand
(3,134 Views)
You should be able to do this using the hidden expression described here, for any Tools Menu Items that you do not want to show in the operator interface.
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(3,129 Views)
Thanks for the reply.
My requirement is to hide the default Tools menu and show only customized tools menu.
Currently I am using the Teststand provided full feature operator interface.(not on sequence editor). When I run the full feature interface ,I am getting all the default tools menu item. I need to only show customized tools menu. The Customized tools menu call the particular sequence from a sequence file to display a Labview VI.
Hope you are aware of the full feature user interface that shipped with Teststand.
Anand
Anand
(3,102 Views)
