NI TestStand
Custom stylesheet, how to retrieve parts of seq file path
We are building a custom stylesheet for our specific needs that is based on the TR5_Horizontal stylesheet. The location that our sequence files are stored in have particular meaning (ex. part, rev, etc.) and I would like to extract those items to be displayed on the test report instead of the complete path to the sequence file.
I'm not really versed in XPath / XSLT so I've not gotten to far. I have tried some function that should help (like tokenize) however, it seems that I am limited to XSL 1.0.
I have found that I can get the path from the name attribute here:
<xsl:when test="contains(@name,'#')">
<span style="margin-left:20px;font-size:70%;font-weight:bold;">
(<xsl:value-of select="substring-before(@name, '#')"/>)
If I want to split the path (ex. C:\..\..\..\part\rev\<testname>.seq) into the desired parts, how would I do this?
(927 Views)
Accepted by topic author pstestek
I was able to resolve my issue with the help of someone outside of this forum. The solution was to create a named template to parse the file path string:
 <xsl:template name="parse-path">
   <xsl:param name="text"/>
   <xsl:variable name="n" select="string-length(translate($text, translate($text, '\', ''), ''))"/>
   <xsl:if test="$n=2">
       <part>
        Part:
           <i><xsl:value-of select="substring-before($text, '\')"/>|</i>
       </part>
   </xsl:if>
   <xsl:if test="$n=1">
       <rev>
        Rev:
       </rev>
   </xsl:if>
   <xsl:if test="$n=0">
       <testname>
        TestName:
           <i><xsl:value-of select="substring-before($text, '.')"/></i>
       </testname>
   </xsl:if>
   <xsl:if test="$n">
       <!-- recursive call -->
       <xsl:call-template name="parse-path">
           <xsl:with-param name="text" select="substring-after($text, '\')"/>
       </xsl:call-template>
   </xsl:if>
</xsl:template>
(883 Views)
