NI TestStand
Custom Error Codes File in Teststand ?
Is there a way to make a custom Error file with error codes and text in Testand like in Labview?
(1,746 Views)
I think your question answer you can find in the following forum link: implement custom error code in teststand
(1,693 Views)
You might consider using Resource Strings. TestStand UIs use them for localization (language). So you can create custom resource strings for your error codes and extract error messages using Engine.GetResourceString.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,655 Views)
