NI TestStand
Creating 'Persistent' Variables inside a running sequence
I am trying add local and file global variables into the a sequence that is running.  I can add the variables fine using PropertyObject.SetValNumber, with the InsertIfMissing flag set, (for example) but this only creates a temporary variable that is lost when the sequence completes.  Is there a way to save this new variable into the sequence file, or is there another way I should be going about this?
Regards
Steve
There are 10 types of people in the world that understand binary, those that do and those that don't.
(4,483 Views)
Hi Steve,
You will need to change the PropertyObjectFile and perform the IncChangeCount to indicate to the engine that the file has changed. Then you can perform the SaveFileIfModified.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(4,481 Views)
Thanks for your reply Ray, think I am still missing something though.
My sequence is attached, temporary variables are cretaed but not saved to the sequence file on completion.
Regards
Steve
(4,475 Views)
Hi Steve,
You will need to set the File objects as well as the runtime objects (I am assuming that you need the values at runtime).
Using the PropertyObjectFile reference get a PropertyObject reference using the AsPropertyObject then  use the Get/Set method to update your values in the file.
Regards
Ray Farmer
Regards
Ray Farmer
(4,471 Views)
Sorry Ray still missing a vital bit of information, my variables are still not being saved into the seq.  Think it is the Sequence File reference I am using to get the Sequence File Property Object.  My call looks like Local.SequenceFileObj = PropertyObjectFile(RunState.SequenceFile).AsPropertyObject.
Attached is my sequence
Regards
Steve
(4,466 Views)
Hi Steve,
try this response, particularly James' initial response to the question.
http://forums.ni.com/ni/board/message?board.id=330&message.id=10706
If you have labVIEW then maybe you will beable to look at the supplied example.
I will try to provide an example later on today.
Regards
Ray Farmer
Regards
Ray Farmer
(4,461 Views)
No need for further examples Ray.  Decoded James's.
Thanks for all your help
Steve
(4,458 Views)
