NI TestStand
Create a source distribution
Hello all,
In Projects of LabVIEW you can create a source distribution builder.
With that I can save all VIs that my Main source code uses (Dependencies field of project contains the directories of all VI's).
I want to do the same in TestStand, that is to say, I have a big sequence with a lot of Vis and SquenceCalls in the some places of my computer. My idea is extract only the sequences and VIs to the one folder, such as i do it in labview project.
Thanks!
(2,548 Views)
Accepted by topic author Arr5
The TestStand deployment utility is actually doing this for you in the Image.  Just create an Image and not an installer and you should have everything in the Image folder.  Don't remove any block diagrams or put your VIs in PPLs.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,514 Views)
Thank you so much. It works perfectly.
(2,446 Views)
