NI TestStand
Create Teststand 3.5 SequenceCall Step use Labview 8.2
Dear ALL:
         I want use Labview 8.2 to create a sequence Call Step,and I know I must get the SequenceCall Module first.In Teststand 3.5 I can use NI Teststand Adapter API 3.5(Ver 1.0) to get the SequenceCall Module,But In Labview 8.2 I can not access to  NI Teststand Adapter API 3.5(Ver 1.0),Because when I Select NI Teststand Adapter API 3.5(Ver 1.0) in "select object from Type Library"(See 1.bmp),It the same as the NI Teststand API 3.5(Ver 1.0),and I can not find SequenceCall Module.
         I think this is the compatible probelm with labview 8.2 and teststand 3.5. When I use Labview 7.1, I can normally select NI Teststand Adapter API 3.5(Ver 1.0).
(3,457 Views)
I do not quite get your point. However, if you want to create a Sub sequence call , why not use the Testand to select the *.vi and create the module autonomously.
Qiushi Shen
DSM Nanjing
NISH
(3,435 Views)
Sherman:
     Thank you for your reply,I want to ask how can I use Labview 8.2 to get the NI Teststand Adapter API 3.5(V1.0).It seems a compatible problem with teststand3.5 and Labview8.2
(3,433 Views)
yiweihua2002,
You didn't say if you were using LabVIEW 8.2 or 8.2.1, so I'm not sure if this truely reproduces your behavior.
However, I just ran LabVIEW 8.2.1 and selected the adapter API, and I was able to see all of the items.
There are a few things I'd like you to try:
1) Run the TestStand Version Selector and make version 3.5 active.  Even if it is already the active version, this will re-register all of the TestStand components to make sure they are properly working
2) Restart LabVIEW (if you haven't already)
Josh W.
Certified TestStand Architect
Formerly blue
(3,404 Views)
