NI TestStand
Collating and Comparing Execution Profiles
Hi All,
Is there a tool to collate and compare the execution profiles captured via "TestStand Execution profiler"? I am running a sequence for 100 times and profiling its execution for every run. At the end I would like to see the total time taken for each of the execution (may be in a table or chart) and also the time taken for the Process Setup, Cleanup and Main sequence run in each of these 100 iterations. Otherwise I will have to manually open the 100 profiles and note down the time for each profile which is very tedious. Any suggestions?
Teena.
(2,480 Views)
Accepted by topic author teenahaldorai
The profiler does have a basic API you can use to control it. See the SequenceFileLoad sequence in <Examples>\Parallel Testing\Comparing Resource Usage Strategies\Comparing Resource Usage Strategies.seq.
You can programmatically load a profile and access the data from a specific table as a string by calling:
Load();
ActiveTable = <desired table>
SelectAll();
String myTableData = Copy();
The data can then be parsed or put in excel for further manipulation.
(2,464 Views)
Thank you, the basic APIs really help!
(2,435 Views)
