NI TestStand
Check if test socket failed using the batch model
Hi
How do i check if a test socket has failed ?
Help share your knowlegde
(3,286 Views)
RunState.SequenceFailed will equal True.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,281 Views)
Thanks.
But can you do the same thing to check with completed test sokects?
For example if i have complete test sockets 1,2 and 3 and im busy on 4 how do i check if test socket 1 has passed or failed.
(3,270 Views)
Hi Shako,
I have found that there are two ways to tell if that particular socket has failed or not. The first way is to check the report tab. The second is a to get the data programatically and display it. You can use an IF flow control step to decide whether or not to display the information. I hope that this helps.
Perry S.
(3,258 Views)
