I have problem displaying result using the horizontal.xsl stylesheet. An error message " Unable to process the XML Report with the stylesheet 'C:\Program Files\National Instruments\TestStand 3.5\Components\NI\Models\TestStandModels\StyleSheets\horizontal.xsl'.
But if changed the stylesheet to expand.xsl or report.xsl the result is ok. I need the report to be in XML format since I'm using it for data analysis. I attach a sample sequence file which the result failed to be displayed using the horizontal stylesheet. FYI this is just a sample sequence file and I have a real of sequence file that have similar problem. I believe the the NOT_OK step (in the attachment) that causing the problem but I don't know what
Is there something wrong with my sequence file step or is it the xsl stylesheet? I'm not reaaly good with XML or XSL so I hope I can fixed this from a sequence file side. Please help me on this since I really need to display the result with horizontal stylesheet.
