NI TestStand
Can't open the xml report file
If I try to open a test report generated by Test Stand I get this message:
The XML page cannot be displayed
Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
An invalid character was found in text content. Error processing resource 'file:///K:/ABU/Projects/PJ0307-PRT2_COM/Work/5_S...
\x17?\x08
ÿþ <HEAD
What am I doing wrong?
(4,503 Views)
Should this 'file:///K:/ABU/Projects/PJ0307.....'
be 'file:///K:\ABU\Projects\PJ0307.....' Is this the path to a failure link?
regards
Ray Farmer
Regards
Ray Farmer
(4,495 Views)
Hi
Can you please post the XML report and the stylesheet which displays the above error.
Thank you
Anand Jain
(4,498 Views)
Please see the attachments
(4,482 Views)
Hi
It looks like your report was missing the encoding attribute in the header. Once I put the encoding attribute it seems to fix the problem.
The report current has <?xml version="1.0"?>
The fixed report has <?xml version="1.0" encoding="iso-8859-1" ?>
TestStand 3.1 or greater puts the encoding attribute in the xml report when it is generated.
Questions for you -
1. What version of TestStand are you using
2. Do you have access to TestStand 3.1 or greater?
If you have access to TestStand 3.1 or greater you can migrate the changes from the "AddReportHeader" sequence in reportgen_xml.seq from the following location
<TestStand>\Components\NI\Models\TestStandModels to your existing process model. If you do so,  you will also need to migrate changes from modelsupport2.dll to your dll.
Hope this helps.
Regards
Anand Jain
(4,475 Views)
Yes that was the problem. Thank you Anand very much for helping me!
I am using Test Stand 3.1
Message Edited by Igor_Jovanovic on 01-26-2006 06:46 AM
(4,455 Views)
