Brian,
You did not mention what is the CVI operator interface that you are using. In the Simple CVI OI, which is located at \Examples\OperatorInterfaces, the behavior you mentioned may occur.
It is mainly because it uses a CVI timer to poll UIMessages, and the Timer Control runs in the same thread as the User Interface (CVI Panels). Because they both run in the same thread, when you move your mouse Windows handles the mouse move and repaint any window if necessary. While doing this, it stops all the other tasks that is running in the same thread, which means, the timer stops to tick and UIMessages are not handled for some time. In addition, the TestStand Engine executes synchronously with UIMessage handling, so if msg
s are not handled the Engine pauses the execution.
Finally, there is an example that ships with CVI under
\Samples\Toolbox\AsyncDem.prj that shows how to use asynchronous timers. In other words, a timer that runs in a different thread different than User Interface. I also modified the Simple CVI OI to use this asynchronous timer, check the attached zip file.
Roberto P.
www.ni.com/support
