NI TestStand
Can TestStand access CVI union and bit field structures?
  I have a relatively large data structure that I am passing to TestStand  which contains different types of scalars, arrays, and other structures including unions.  I was wondering how I would define a union or bit field in TestStand so that I can access the individual elements of the union.
typedef struct BINCODES
{ // BINCODES
    unsigned char    current:1,             // 1        Max or min exceeded
        programming:1,         // 2        Readback <> written. NOTE:!!!!! Readback on A4 is faulty and should not be binned on.
        code_range:1,         // 4        Outside normal range
        convergence:1,         // 8        Failed to converge after 4 fine sensitivity rounds.
        off_axis:1,         // 16        Off-axis sensitivity is too great.
        self_test:1,         // 32        Next version: self-test response is improper (too low or high)
        ratiometricity:1,   // 64        Next version: ratiometricity too high
        soft_rst:1,         // 128        Score too low.
        temp_comp:1,             // 256
        alignment:1,        // 512        Misalignment too great for pick and place.
        vacuum_at_sckt:1,   // 1024        Vacuum fault when picking or placing a part on the tray.
        tip:1,                // 2048        Stability of measurement is insufficient since reference measurement is not consistent.
        vdd:1,                 // 4096        Vdd is not within expected range.
        mux:1,                // 8192        Mux failure.
        final_offset:1,     // 16384    Final offset is out of specification.
        rail:1,             // 32768    Railed part is not close enough to rails.
        dig_vfy:1,        // 65536 Digital and Analog values out of tolerance
        comm:1,            // 131072    I2C and SPI don't match
        registers:1,    // 262144    Failed register write test
        interupt:1,        // 524288    Failed Interupt test
        retest:1,        // 1048576    Failed retest
        lost_part:1,    //    2097152    Failed to identify chip based on RC and Codes.
        oscillator:1,    //    4194304    Oscillator failed to trim sufficiently.
        humidity:1,       // 8388608
        EEPROM:1,        //    16777216
        PotFrit:1,        // 33554432
        ScanVect:1,        // 67108864
        b27:1,            // 134217728
        b28:1,            // 268435456
        b29:1,            // 536870912
        b30:1,            // 1073741824
        b31:1;            // 2147483648
} BINCODES;
typedef union BIN_UNION
    long        fullcode;
    BINCODES    singlecode;
} BIN_UNION;
The BIN_UNION is buried inside another structure.  I basically want to be able to set various bits based on the results from a step hopefully without having to use an accessor method in the DLL.
Mike
Message 1 of 1
(3,786 Views)
