Hi Mike,
Do you mean like in the BMP I have attached.
If, so check out the TestStand 2.0.1 User Manual Chapter 9 - 53 Step Type Menu Editor.
In the Group Settings controls, the SubMenu check box is the control you use.
Open the Type Palette Window, Select your ini file in the Palette control. Click on any of the step types and right mouse click. Then select the Step Type Menu Editor.
I hope this helps
Regards
Ray farmer
Regards
Ray Farmer
