NI TestStand
Can I Suppress Conflicting Names Messages in the TestStand Deployment Log?
I have a deployment that is being built via a command line calling the deployment utility. It is all being done with a script. I then use the deployment log for information to e-mail to myself and others about the build. I am getting conflicting name messages for VIs in the Labview Reports library that is shipped from NI. There are a lot of message about VIs being renamed because of this. Is there a way of suppressing these messages so real information can be observed and not missed because of all this spam? I don't want to have a real problem over looked because of these messages being generated about items that are not in my control. Thanks in advance for any help.
Troy
(3,557 Views)
What version of TestStand, and LabVIEW are you using? Have you seen How to Successfully Deploy a TestStand System with LabVIEW 8.6 and Report Generation Toolkit ?
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(3,534 Views)
I am using TestStand 4.1.1 and Labview 8.6.1. I have looked at the link you are referring to. That I believe is how to make the deployment work with the Report Generation Toolkit. I believe I would still get the same warnings in the deployment log which is what I am trying to get rid of.
Troy
(3,525 Views)
Hi Troy,
I don't believe TestStand has the option to customize which warnings are logged and which aren't. The best thing to do would create a tool to parse through the log and find the warnings with the duplicate name warning to remove.
(3,489 Views)
