NI TestStand
Calling user created Teststand sequence from .NET?
Hello All,
    I created a sequence in sequential process model. Now my question is, Is there a way to call the user created sequence (or) any sequence of a process model from .NET.
Arun
(4,802 Views)
Do you call it from UI or from Code module ?
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,794 Views)
Hi Juergen,
    I call it from .NET code module
Arun
(4,790 Views)
HI Arun,
unless i do not understand why you want to perform in a step module a SequnenceCall
I would do it  this way create a new  Exection and wait for end
it looks like this:
StationOptions stationOptions = engine.StationOptions;
stationOptions.AllowOtherModels =
true;
String strAbsolutePath;
Boolean bUserCancelled;
// Get the sequenceFile
if (engine.FindFile(strFileName, out strAbsolutePath, out bUserCancelled, FindFilePromptOptions.FindFile_PromptHonorUserPreference, FindFileSearchListOptions.FindFile_AddDirToSrchList_No, false, null) == true)
SequenceFile seqFile = engine.GetSequenceFileEx(strAbsolutePath, GetSeqFileOptions.GetSeqFile_OperatorInterfaceFlags, TypeConflictHandlerTypes.ConflictHandler_Error);
// Get the Model
if (engine.FindFile(strModelName, out strAbsolutePath, out bUserCancelled, FindFilePromptOptions.FindFile_PromptHonorUserPreference, FindFileSearchListOptions.FindFile_AddDirToSrchList_No, false, null) == true)
seqFile.ModelPath = strAbsolutePath;
seqFile.ModelOption =
ModelOptions.ModelOption_RequireSpecificModel;
String strModelDescription;
SequenceFile seqFileModel = seqFile.GetModelSequenceFile(out strModelDescription);
// Get the Single Pass EntryPoint
String strEntryPoint = "Single Pass";
Sequence sequence = seqFileModel.GetSequenceByName(strEntryPoint);
if (sequence.Type == SequenceTypes.SeqType_ExeEntryPoint)
Execution execution = engine.NewExecution(seqFile, strEntryPoint, seqFileModel, false, 0,null,null,null);
execution.WaitForEndEx(-1,
true, null, null);
else
Console.WriteLine("ModelFile {0} not found", strModelName);
else
Console.WriteLine("Teststand File {0} not found", strFileName);
BUT !!!!!
I think the best would be set a TS Locals bolean in your Module and perfom it in next step with precodition and step sequnce call
greetings
juergen
--Signature--
(4,778 Views)
