NI TestStand
Calling LV and python modules in same sequnce file
I have created a test sequence file which mainly calls LV modules. I have also configured TestStand to use LabVIEW as 'Selected' in Adapter Configuration settings. Now, I need to call also python modules in the same sequence file. I am wondering if it is possible and if it is, which adapter I should select in Adapter Configuration? LabVIEW or Python?
-Jick
(779 Views)
Different ways for choosing adapters:
Before placing a step
After having placed the step
(772 Views)
The selection in Adapter Configuration is just the default one used by the Step Types. They are all active, and so it doesn't matter which one is selected, and instead just matters the Step Type you drop down as mentioned above.
(750 Views)
Ok, thanks! That's good to know.
-Jick
(737 Views)
