NI TestStand
Calling ExpressionEdit and selecting text from VB.NET
I have a problem when using the ExpressionEdit control. When the control is displayed I would like to have the text expression hi-lighted so that anything newly typed or selected will automatically overwrite what is already there. The problem is when I call the SelectAll method of ExpressionEdit. This should select all the text but has no effect. When the control is displayed I only ever have the first character selected. Here is some example code, any ideas where I'm going wrong?
Public Sub TestExpressionEdit(ByVal objSeqContext As NationalInstruments.TestStand.Interop.API.SequenceContext)
Dim objExpEdit As NationalInstruments.TestStand.Interop.UI.ExpressionEdit
Dim poSeqContext As NationalInstruments.TestStand.Interop.API.PropertyObject
Dim bCancelled As Boolean
poSeqContext = objSeqContext.AsPropertyObject
objExpEdit = New NationalInstruments.TestStand.Interop.UI.ExpressionEdit
objExpEdit.Context = poSeqContext
objExpEdit.Text = "Step.Result.Numeric"
objExpEdit.SelectAll()
bCancelled = Not objExpEdit.DisplayBrowseExprDialog()
If Not bCancelled Then
Debug.WriteLine(objExpEdit.Text)
End If
objExpEdit = Nothing
poSeqContext = Nothing
End Sub
(3,115 Views)
It looks like the ExpressionEdit control window is not actually getting created. There's a couple things you can do. One is ensure the window is created by creating an AxExpressionEdit instead of a ExpressionEdit and placing the control in a container. The following code demonstrates this:
Public Sub TestExpressionEdit(ByRef f As Form, ByVal objSeqContext As NationalInstruments.TestStand.Interop.API.SequenceContext)
Dim objExpEdit As NationalInstruments.TestStand.Interop.UI.Ax.AxExpressionEdit
objExpEdit = New NationalInstruments.TestStand.Interop.UI.Ax.AxExpressionEdit
f.Controls.Add(objExpEdit)
objExpEdit.Visible = False
f.Controls.Remove(objExpEdit)
End If
End Sub
However, if you just want to display the Expression Browser dialog box and do not need an ExpressionEdit control, you can do this by calling Engine.DisplayBrowseExprDialogEx().
(3,106 Views)
