NI TestStand
Call a teststand sequence from CVI
I am planning to call a teststand sequence from LabWindows/CVI. Is there any reference for doing this?
Ramjee
(3,028 Views)
Ramjee,
when installing TestStand, there are also User Interfaces installed with it. There are two different UIs for five programming languages, one being CVI.
I suggest you to start from this (most probable the "Simple"). If the call is done automatically, you can use the Application Manager to load and the SequenceFileView Manager start your execution.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,013 Views)
