NI TestStand
Call Executable - Close command prompt
i am running the Call Executable step that executes a batch file.
In the batch file another exe file is called.
Now the question is: How can i close the appearing cmd window (which contains the batch-file command) so that the teststand-sequence can contine?
Currently teststand is waiting at the call executable that the called program is returning.
I tried the option "Wait for exit = No Wait" but this does not help.
Thx
Message 1 of 8
(5,360 Views)
Strange, even pausing with the No Wait set!!  Are you able to post more information?
Message 2 of 8
(5,326 Views)
You can reproduce this by creating a batch file and write the text "notepad" inside.
When running this file then Notepad is started and the command-window is opened until you close the notepad window.
This happens also identical if you run the batch-file direct from the windows-explorer.
Is there any way that this does not happen?
Thx
Message 3 of 8
(5,324 Views)
Way ahead of you dude.  I did some testing before my previous post (I don't use the Call Executable step very often).  I created an EXE (in LabVIEW) and a Batch File that calls my LV EXE.  Created a TestStand sequence with a Call Executable step that calls my batch file.  I tried it with "Wait" and "No Wait" and I am not seeing the behaviour that you are describing which is strange.
Message 4 of 8
(5,322 Views)
Can you test what happens with "notepad" in your batch-file?
Is your lv-exe also still running and CallExecutabel can continue? strange
Message 5 of 8
(5,315 Views)
The CMD Window opens, running the Batch file, and Notepad is launched.  When I manually close Notepad, it closes following by the CMD Window.
If I set the Call Executable step To "Wait for Exit"  TestStand pauses at the Call Executable step until I close Notepad (and the CMD Window has closed).
If I set the Call Executable step To "No Wait"  TestStand does not pause at the Call Executable step.
Message 6 of 8
(5,312 Views)
Ok, my fault. Its working here too.
I thought that the command-window whould be closed when setting to "No Wait"....
But it works as it should when changing the Wait-option.
Message 7 of 8
(5,306 Views)
Cool. I guess your EXE is not returning?
Message 8 of 8
(5,298 Views)
