02-10-2012 05:46 AM
Excatly, the wapper encapsulates high level access to Ni-Teststand while all api-calls to vector are done in the wrapper.
You already took a look at Vectors.net api and saw that it deals with events. I have doubt that you have access to them in TestStand.
On the other hand there were a some exception handler in vectors api if a functions are failing. The inside wrapper you will be able to manage them
and set for instance an errorflag in TestStand or what ever you want to do on error.
For doing this I have used C# and built a .net assembley.
Normally you could use your favourit programming language to create a wrapper
Hope this helps
Juergen
02-10-2012 11:40 AM - edited 02-10-2012 11:42 AM
Hi Juergen,
We actually do have a set of custom step types that allow you to register and wat for .NET events directly in TestStand. I have uploaded the step types along with an example of using them on the NI community (credit to Doug for creating them) :
NI Developer Community: TestStand .NET Event Handler Step Types
The document in the attached ZIP file provides a lot of detail on how to use the step types, so definitely take a look at it before using the step types. We would definitely appreciate any feedback you have on these steptypes, so let me know if you get a chance to try them!
02-17-2012 02:28 AM - edited 02-17-2012 02:29 AM
Juergen, Thanks. Is it possible to give me the source C# code ?
02-17-2012 06:35 AM
Hi sfla,
I am not allowed to publish or sell the source code.
I recommend to ask a regional Ni Alliance Partner to buy the
the code or they develop one. I am quite sure they will help you.
Another option is to try the attached .net step type
At the moment i had no time to figure out the features
Regards
Juergen
