NI TestStand
CAN Frame through UI Message
Hello guys,
Running my tesstand sequence, I am trying to send from my CAN VIs the output Frame signal through UI Message to my custom UI, I hace created a custom data type in test stand and then I linked that data type to the UI message using the activeXdataparam, from the teststand context I have no errors but my User interface simply does not show any CAN frame, do you have any idea how to do this?
thanks for your support
(2,357 Views)
What are you doing with the Variant in your UIMessage callback?  You cannot just do a Variant to Data (like you would expect).  You have to access each piece individually (kinda painful).
I learned my lesson back in the day: https://forums.ni.com/t5/NI-TestStand/Pass-Cluster-Type-Value-from-TestStand-to-UI-Using-TestStand-A...
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,333 Views)
