NI TestStand
C# DLL struct
I am trying to demonstrate how TestStand can retrieve data from a  C# DLL method returning an array of type struct.
I created a custom type in TestStand that matched the signature .NET struct but I keep running into the same error:
"No corresponding subproperty in argument 'Locals.newarray<Array Element prototype>' of type 'Row' for field '<mystring>k_BackingField of .NET struct 'TestStandObjectArray.Row'."
I have set the ".NET Struct Passing" tab to "Allow Objects of this Type to be Passed as .NET Structs".
I have also tried "Exclude when Passing Struct" on this tab as well.
I have attached my DLL, CS file, TestStand sequence, and TestStand types.ini file.
Any tips or help would be appreciated.
(5,752 Views)
Accepted by topic author tempacheer
I think I see what the problem is. You made the members of Row properties rather than fields. Instead of:
    public struct Row
        public string mystring { get; set; }
        public bool mybool { get; set; }
try this:
    public struct Row
        public string mystring;
        public bool mybool;
The notation you are using "{ get; set; }", is a C# language shortcut for declaring a private field you don't care about accessing from code directly (that's why it gets named with k_BackingField) and a property to wrap it. TestStand struct passing only operates on fields, not properties.
Hope this helps,
-Doug
(5,732 Views)
Thanks for the quick response Doug!
I'm not sure that I would have figured that out because we use properties almost exclusively for public members in C# classes!
Good catch, and the error makes perfect sense now!
(5,706 Views)
