NI TestStand
Byte Array Conversion into ASCII format
Hi everyone,
Is there a way in Test Stand to convert a Byte Array into concatenated ASCII format?
Thanks!
(6,039 Views)
Hi testdesign,
Do you want to convert your array into a string? If so, using the Str function would provide you with the functionality you're looking for.
Here is the help document on the function: http://zone.ni.com/reference/en-XX/help/370052N-01/tsfundamentals/infotopics/str/
(5,996 Views)
If you have an array of numbers in teststand that correspond to ascii values you can convert that to the corresponding string by writing a loop which does something like the following:
Locals.myString += Chr(Locals.myNumberArray[Locals.myLoopIndex])
Chr() converts ascii values to characters in TestStand expressions.
Hope this helps,
-Doug
(5,980 Views)
Thanks guys.  That'll work for me Smiley Wink
(5,971 Views)
