NI TestStand
Building a sequence using API - XML
I'm using a XML file to create a sequence file dynamically. I create Subsequence call programmatically using lookupstring in XML (Module.SeqName for Sequence and Module.SFPath for File Pathname)
Any idea what Lookupstring should I use to send parameter values to the sequence I'm calling?
Message 1 of 1
(1,850 Views)
