NI TestStand
Batch result will not pop up automatically
I am using Test Stand 3.5 and came arcoss an issue: when the test sequence ends, ocassionally the batch result will not pop up automatically. The result will only pop up when I click a mouse button or hit a key in the keyboard.
Any idea?
Ryan
(4,595 Views)
Hi Ryan,
if the dialog box is application-modal, it won't pop up if another application has the focus or at least TS does not have it.
Could this be an issue?
Regards
Oli
(4,577 Views)
Hi Oli,
Yes it could be. Acutually, my test sequence will call a .bat batch file which in turn call an execute file to perform some action. I now suspect there is something wrong with the execution of the execute file which holds the focus.
Thanks for the input.
Ryan
(4,536 Views)
