10-27-2016 09:00 AM
Is there anyway to show failed step at the UIMeassage generated by postuut sequence of Teststand?
BTW the sequential model i use is batch model
10-28-2016
12:22 PM
- last edited on
07-13-2024
04:52 PM
by
Content Cleaner
Hedehodo,
This is Ali from National Instrument's applications engineering. I will be helping you with your issue today. Have you had a chance to Using TestStand User Interfaces or Best Practices for TestStand UI Development. The Using TestStand User Interfaces does include a custom example on how to have custom messages.
Additionally, here is some more detailed information on some of the properties you would be dealing with:
Example for Operator Interface
Memory issues that might come up with customization (I would keep this on file but it shouldn't seem to be an issue for you)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1w9CAA&l=en-US
11-04-2016 01:22 AM
Actually i need to edit TS standard messages especially while showing test result at batch model
11-05-2016 02:43 PM
Hedehodo,
Just to be clear you would like to edit the results to show more detailed information or to customize results.
Are you trying to remove information/add/ or try to change how things are showing?
