NI TestStand
Array of different Custom Data Types
Could you help please on how to create an array of different Custom Data Types?
I have created already 2 different Custom Data Types in TestStand.
Now I need to create an array of different Custom Data Types, so for exaple:
MyArrayOfDifferentDatatypes[0][0] = MyPoint1
MyArrayOfDifferentDatatypes[1][0] = MyPoint1
MyArrayOfDifferentDatatypes[0[1] = MyPoint2
MyArrayOfDifferentDatatypes[1[1] = MyPoint2
The thing why I need to create something like this is because I have a big #DEFINE list in C that I'm trying to simulate in TestStand using Custom Data Types. I need to use these "DEFINES" over all the Sequence so I if for any reason any DEFINE value changes I will have only to modify the Custom Data Types so changes will be reflected over all the Sequence.
Or of you know a way on how to simulate a C DEFINE list in TestStand let me know.
I'm using TestStand 2016 SP1
Thanks for the help.
(2,183 Views)
Accepted by topic author elirofu1
I'm not exactly sure what you mean by simulate C define, but I've attached a sequence that illustrates different ways to make a single array that contains different custom data types.
(2,124 Views)
@James,
Thanks for your reply!
I have a code in C that I'm trying to port into teststand, the current code I have have several functions that uses several of the already defined values in the .h file in the C project.
example:
#define POINT1 "12345"
#define POINT300 "54565"
I need to use these #define values in all my C code functions and since I will call these functions from testand I would need to pass these values to the C function, but since teststand do not know the value of the actual #define I need to pass the #define value "12345" instead the #define (POINT1) itself, also I have decided to use CustomDataType to stay away from global variables in testand.
Thanks for your help. the sequence worked.
PS if you have a better way to do this please share it.
(2,121 Views)
TestStand definitely doesn't have C-like macros or header files.
If you were strictly using numeric values instead of strings, defining an enumeration type might be an option.
Instead of creating a datatype per constant, you could instead provide multiple constants with a single datatype by making a type based on Container, maybe call it MyPoints, and adding sub-fields in the container type for each constant, such as Point1 and Point2.  You will still need to instantiate a variable of that type somewhere to be able to reference your 'constants', but you only have to add a single variable of that type to make all its fields available to expressions in your sequence.
In the type editor, you could go to Properties>>Advanced>>Flags>>Type Flags>>Instance Default Flags and checkmark PropFlags_NotEditable on each field to make the fields seem a little more 'constant', but they will still be possible to assign to programmatically.
(2,092 Views)
