NI TestStand
Applying Database Options on another station (TS Labview API)
We want to deploy TS sequence with database logging enabled but are unable to figure out how to push the database settings to the production machine - so my question is:
What are the options to transfer what I setup in "Result Processing > Database Settings" on the development station to the user station?
The intention is basically the same as in this thread: https://forums.ni.com/t5/NI-TestStand/How-do-I-deploy-the-Database-Options-on-a-Second-station/m-p/1...
 - but i don't want the end-user to do anything manually - at most install the ODBC driver.
Another restriction might be that the end-user application is built with Labview.
Thank you for any advice.
(2,466 Views)
You should use the deployment tool and add your database ini files from your Cfg, modelPlugins and ModelCfg into your workspace.
The tool will install that files on the target machine and TS will be set automatically at the next restart.
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(2,435 Views)
