02-25-2014 04:40 AM
I get very mystic error when calling DAQmx Create Channel (Digital input) and DAQmx Read (Digital Bool 1Line 1Point) vis. Difficulty is that it does not occur every time. It is random. Any ideas what might cause this error? I uninstalled Traditional DAQ drives because they are not in use but it does not help.
Please, see attachment.
BR,
Jick
02-25-2014 07:44 AM
Hey Jick,
Does this error occur if you run the VI independently of TestStand? If so, you might want to post this on our Multifunction DAQ board. The users who are active on that board have more experience with the DAQmx functions.
I would also recommend opening MAX and trying to use the test panels for your DAQ device. It's possible that you will see this error in MAX as well, which might give us more information to narrow down the issue.
02-25-2014 08:27 AM
Here is some additional information. See attachments.
I can not get that error using MAX or looping it only. There is something else outside which causes the error. It can not be Traditional DAQ because I uninstalled it. These vis are running in a loop during the test in the batchmodel.
BR,
Jick
