NI TestStand
Adding two array in teststand
Need to add two array in teststand locals. Array A need to plus ArrayB -1. I can get GetNumElements(ArrayA) to get max elements.Using a for loop to nest between 0 to 8. Teststand explains there is error, out of bounds, because teststand array stands from zero but when execution everything works.
How to stop the prompt? Or how to get the elements without minus one. Is there a function offsetToIndex(array,offset) which return the elements in the array
(497 Views)
To me it looks like you are adding two array with different sizes and the number of loops is using the number of elements of the larger one?
BTW... all decent programming languages start addressing arrays at 0 😉
(482 Views)
