NI TestStand
ActiveX -17502 System Level Exception
I've compilied a VI in LV2009 into an ActiveX server. I've tested the ActiveX functionality with a calling VI to read a control value and it works fine. It opens the executable using the "Automation Open Function"; uses the method "Get VI Reference" to get the reference; then uses that reference to get the control value.
If I try to create a VI reference from the Teststand 4.2 ActiveX COM adapter, the sequence throws a "17502 System Level Exception" error. The executable does open, and does work once it's opened if I run it manually. The 'ERROR OUT' cluster on the front panel does not indicate any error.
I've attached screenshots of the LV block diagram and the TestStand step in case I'm missing something. The path to the VI was copied form the LV string path so it's obviously correct.
I'm baffled by this one.
(5,374 Views)
@Cabman wrote:
[..] The path to the VI was copied form the LV string path so it's obviously correct.
No, it is not correct as it does not address escape characters.
Nevertheless, error -17502 indicates another issue. I guess that your VI isnt executing at all.
So please test what happens if you pass an invalid path in your LV test environment.
Also update the exe with debug options so you can make sure that TS calls the exe correctly as you currently seem to believe.
Norbert
Norbert
Expert: Geometry
(5,347 Views)
Accepted by topic author Cabman
Don't do Create From File, that's not what that setting is for. That setting is for deserializing an object saved to disk. You should be using the default setting of "Create New" instead. TestStand will find your server using the Windows registry (really the OS is what does that) you do not need to specify a path to your server.
Hope this helps,
-Doug
(5,334 Views)
Hope this helps,
-Doug
This is what I did before with LabVIEW 7.1, but with LabVIEW 2009 it was throwing this error:
"An exception occurred calling 'GetVIReference' in '_Application' of 'MightexCCDSnapControl 9.0.1f3 Type Library'
LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
Source: LabVIEW"
I had found a Knowledge base article describing this issue occured with LV8.6 and later and was under the impression that it would not longer work for me. But I took the advice from the previous post and added the escape backslash to my path backslashes and it's all working now.
Thanks Smiley Happy
(5,319 Views)
@Cabman wrote:
Hope this helps,
-Doug
Source: LabVIEW"
Thanks Smiley Happy
@I think that error was referring to the path specified as a parameter to the GetVIReference method. In newer versions of TestStand you can use the @ symbol to avoid having to escape backslashes in expression string literals. For example:
@"c:\mydir\myfile"
is equivalent to:
"c:\\mydir\\myfile"
-Doug
(5,300 Views)
