NI TestStand
API Method to display LabVIEW Adapter Configuration Dialog Box?
I'm looking for an API method to display LabVIEW Adapter Configuration Dialog Box programmatically. There is the method Engine.DisplayAdapterConfigDialog to display the higher-level dialog but I didn't find an API method which displays the LabVIEW Adapter Configuration Dialog Box directly.
Kind regards
Christian Dietz
Christian
Test Engineering
digades GmbH
www.digades.com
(4,483 Views)
Christian, currently there is no API option to display a single adapter configuration dialog. Your only option is to create a custom dialog that uses the LabVIEWAdapter API interface to expose the settings of interest.
Scott Richardson
https://testeract.com
(4,371 Views)
