NI-TSN (1588 and 802.1AS Synchronization)
Time Precision Protocol Switches
A switch supporting 802.1AS or 1588 timing protocol is required to build a network of NI TSN devices. Some devices like the cDAQ-9185/9 and FieldDAQs have a build in switch which allows them to be connected in a line topology.
CompactRIO and Industrial controllers do not have a build in switch and therefore it is required to use a 802.1AS/1588 enabled switch to synchronize three or more controllers.
Refer to this white paper for more information about ethernet topologies.
802.1AS enabled switches tested with NI-TSN devices:
cRIO-9805:
CISCO IE4000:
Message 1 of 1
(2,105 Views)
