NI-TSN (1588 and 802.1AS Synchronization)
Ethernet/IP driver for cDAQ-9185?
I want to make my cDAQ-9185 visible on my OT network to communicate to other automation devices using Ethernet/IP. I have FlexLogger Proffessional and was hoping I do not have to purchase a license for the driver to achieve my goal.
I understand I can also use OPC UA, but I know nothing about configuring this setup. Ultimately, I want to snynchronize recorded cDAQ-9185 data with recorded Rockwell Automation motor drive data trends.
(378 Views)
The driver for the Ethernet-based cDAQs should be bundled with NI-DAQmx.
Have you tried installing the latest DAQmx and seeing if it shows up in MAX under Network Devices?
These resources might be helpful.
Troubleshooting Network cDAQ Connectivity Issues - NI
Verifying the Installation in MAX - NI
(143 Views)
