NI Package Manager (NIPM)
Remove all NI packages
FWIW, I just found a scenario where I wanted to remove everything (except for NIPM). I saw (and kudoed) the idea exchange post for it but needed a solution in the short term. In case anyone else finds themselves in this scenario, I did the following using powershell and a bit of excel/notepad++ trickery. (There's probably a cleaner way, and you could easily write a VI to do this, but I /hope/ I don't have to do it again, so I just brute-forced it.)
1. Run the following:
PS C:\Program Files\National Instruments\NI Package Manager> .\nipkg.exe list-installed | Out-File c:\temp\packages.txt
2. Open packages.txt with excel and sort on first column
3. Delete all other columns; save it (still as a .txt file)
4. Open the text file in notepad++ or similar; replace all \r\n sequences with a single space
5. Copy that entire string in to the clipboard
6. Use the following command
PS C:\Program Files\National Instruments\NI Package Manager> .\nipkg.exe remove -y -v --allow-uninstall <your string here>
7. You'll probably be greeted by one of two things:
  • First, you might get a message saying the command is just too long. In that case, grab a portion of the string and just rerun the command with a subset of the packages.
  • You will also get the following:
Conflicting requests.
Solution 1:
- Cancel removal of 'ni-package-manager'
Solution 1:
- Cancel removal of 'ni-package-manager-deployment-support'
Solution 1:
- Cancel removal of 'ni-package-manager-released-feed'
Solution 1:
- Cancel removal of 'ni-package-manager-upgrader'
  • Go back to the text editor and remove the packages that it suggests from the string.
  • Rerun.
(3,981 Views)
Hi Chris,
See my latest comment on the idea exchange post. 🙂
Thanks.
Aaron Peña
Product Owner, Package and License Management
(3,967 Views)
As for the steps from 1 to 5, if you are using WSL/WSL2/GNU tools (windows version),
then you can get that long string by executing,
$ /mnt/c/Program\ Files/National\ Instruments/NI\ Package\ Manager/nipkg.exe list-installed | awk '{print $1}' | sed ':a;N;$!ba;s/\n/ /g'
(3,555 Views)
