NI Package Manager (NIPM)
Error while installing MSI
This is what is says in the error log:
Exception in ni::pkgclient::TransactionBase::StartInternal. Error code: -125083
Request type: 30
-125083: An error occurred while installing a package: ni-package-manager-deployment-support (20.5.0.49152-0+f0)
File: source\nipkg_client\pkgclient\PluginInteraction.cpp
Line number: 235
Additional error information:
-125530: An error occurred while installing the MSI at 'ni-package-manager-deployment-support.msi'.
File: C:\dev\23\s\nipkg\source\shared_agents\WinInstall/ErrorHandler/ErrorInfo.h
Line number: 103
Why is this happening and how can I fix it?
Message 1 of 33
(47,752 Views)
jstrot,
I would look at the NIPM logs as they may have some more information. This page the location and how to turn on additional information to the logs. NI support will ask for these to help you resolve the issue.
What action were you trying to preform when this error happened? Updating NIPM? New installation of xyz?
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
Message 2 of 33
(47,719 Views)
I was trying to install NI ELVISmx at
https://www.ni.com/en-us/support/downloads/drivers/download.ni-elvismx.html#305452
I have also tried to install LabVIEW and Multisim through the Academic Site License download page.
https://www.ni.com/en-us/support/downloads/software-products/download.academic-site-license.html#333...
The problem is, the Package Manager itself will not install for some reason, even if I try to download it separately from:
https://www.ni.com/en-us/support/downloads/software-products/download.package-manager.html#322516
I always get the same error listed above.
EDIT: I tried on a different computer and there are no errors, there must be a problem with the current computer I am using.
Message 3 of 33
(47,713 Views)
Have you tried the offline installer for NIPM that is available on the download pages lower right corner?
Bill Eisenhower
Message 4 of 33
(47,696 Views)
Yes - the problem is something on that machine, possibly either the Windows MSI engine is in a bad state or some default Windows directory is inaccessible.
As mentioned above, follow this KB to enable MSI logging, run the installer again (it doesn't matter which one), and post back a zip of the log directories it mentions.
Message 5 of 33
(47,692 Views)
Accepted by topic author jstrot
I figured it out, I was missing several registries that deal with MSI.  The fix involved resetting Windows, now everything works properly, thanks everyone!
Message 6 of 33
(47,683 Views)
hi , how did you fixed the problem please , could you teach me because iam tired from this issue , please contact me on my email / ahmed95marei@gmail.com i would be happy if you help me out
Message 7 of 33
(46,681 Views)
So I was able to get it to work.
First, I did as suggested above:
  1. Went here: https://www.ni.com/en-us/support/downloads/software-products/download.package-manager.html#322516
    and downloaded from the bottom right corner:  Individual Offline Installers
    and installed the package manager
  2. Then downloaded and installed Labview Community Edition
  3. Labview CE was not recognized or activated so I followed the steps here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YN7rCAG&l=en-US
    which require redownloading Labview CE but did not have to reinstall.
  4. Opened NI License manager and clicked on 'Activate Softwaer'->'activate'
    And this did the trick for a 365 "trial" of Labview CE
Hope this helps
Message 8 of 33
(46,250 Views)
A simple system restart will work.
Message 9 of 33
(45,846 Views)
I tried every possible solution nothing works for me, can some one help me
Message 10 of 33
(44,153 Views)
